Correct cylinders for 1994 964
Hi All,
Are these considered to be the correct cylinders for a 1994 964? Thanks! Q.http://forums.pelicanparts.com/uploa...1442092832.jpg http://forums.pelicanparts.com/uploa...1442092851.jpg http://forums.pelicanparts.com/uploa...1442092877.jpg http://forums.pelicanparts.com/uploa...1442092894.jpg http://forums.pelicanparts.com/uploa...1442092914.jpg |
964 103 915 22 is the correct number for the piston and cylinder set for a 1994 Porsche 964.
The box shows the correct number for later model 964's, however the cylinders and pistons seem to be the earlier cylinders/pistons....
Early 964 cylinders had the conventional style sealing surface No gasket and no head support around the studs.. Much like the 3.2 Carrera cylinder. There were two different late cylinder types that used gaskets. One used the asbestos/paper gasket and the other used an aluminum ring style gasket. The cylinder pictured appears to use the asbestos style gasket. |
Does either have an advantage over the other, Henry?
Thx. Quinn |
I don't have enough information to give a definitive answer. |
ok, I'm even more confused than usual. PET lists 964.103.915.22 for use in M64.01, 02, which is C2 NA, as well as M64.50 - which is 964 Turbo. ?!?!?!
PET lists 964.103.915.25 for use in M64.01/02, after 1991, only - not turbo. Did 964 turbo and NA use the same pistons? |
These are definately not those pistons/cylinders. I don't know what later Ps&Cs look like but something in my memory tells me they had a elivated deck piston. |
I show the part number that I used for the updated P&Cs for my 964 to have been
964-103-915-22 These are the upgraded P&Cs and appear to be the same as your photos Been in the car for several years now. http://forums.pelicanparts.com/uploa...1661031166.jpg |
| All times are GMT -8. The time now is 07:46 AM. |
