Oil Line Fitting
We have had two early 2.2 litre magnesium engine cases with stripped threads where the oil line adapter screws into a boss. (Part No. 999.136.008.09).
The boss on the mag cases is quite small and I don't like the idea of re-tapping and fitting a helicoil as the thickness in this area is not so good and if it fails you are then left welding up the case.
If you look carefully into the case there is a depth of around 35mm below the thread which has not been tapped and is the correct diameter for an M22 x 1.5 thread.
We have made an M30 x 1.5 fitting with an extra 20mm of M22 x 1.5mm thread.
By tapping down into the existing hole the new fitting is straightforward to install and solves the problem without taking a risk with a helicoil.
M22 x 1.5 taps are available for around $15 on EBay.
We made the new fittings in 6AL4V Grade 5 Titanium and they have worked quite well.
Old 09-23-2015, 07:23 AM
Kartoffelkopf
Spenny_b's Avatar
Cool!
Have done similar things recently; buying taps on eBay and making my own adapters to interface various components (although not on the scale of M22...yet)
S
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 09-24-2015, 05:17 AM
