88 porsche 3.2 pistons
I am about to purchase new pistons to rebuild the engine. I have the camshaft reground to 964 specs. I need to know what compression piston do I need to match the 964 camshaft with a stock engine.
Old 02-20-2016, 09:11 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
The stock compression ratio works fine with the 964 grind. Are your pistons damaged? If you are replacing them, you will need to know which cylinders you have, Nikasil or Alusil. Rings are different between cylinder types too. Lots of info on this in the forum, use the search tool. You are beginning the journey!
1986 Targa Guards Red
2021 MT09 SP
Old 02-21-2016, 03:35 AM
