stuck / seized CHT sensor on 3.2 engine
Rather that cut the wire & use a regular socket (always a failsafe, albeit not cheap), adding a hose clamp to a slotted socket really improves the grip on a recalcitrant sensor.
http://forums.pelicanparts.com/uploa...1443360127.jpg |
I will remember to try that when I need to.
Thanks for the tip. |
| All times are GMT -8. The time now is 11:03 AM. |
