Cyl Head exhaust stud spacing dimension?
What is the distance between centers of the exhaust studs in the head on a 1986 911 turbo. I measured 2.575 with calipers. It's hard to measure with the heads on the engine.
Thanks David |
It would be a metric measurement.
Measure outside to outside of the studs with your caliber, then measure the stud and deduct that from your first measurement, you should arrive at 66 mm. http://forums.pelicanparts.com/suppo...s/beerchug.gif |
| All times are GMT -8. The time now is 03:30 PM. |
