Bolt pattern, head to cam tower
I will make a fixture for surfacing of cylinder heads (3.0/3.2)...does anyone have a dimensional sketch of the bolt pattern of the studs and guide pins? Please share if you have, thanks:)
Robert |
If I am understanding correctly...You want the bolt pattern for the Heads to Cam Housing??
Hopefully I have what you need. Cheershttp://forums.pelicanparts.com/uploa...1443560112.jpg |
Robert I chopped up a defective cam tower maybe 30 years ago and am still using it.
If I make a new one I will send you the file but for now I am a little busy. kan du glemme gamle norge |
Thanks for your reply...maybe my request was a little unclear, this is what I'm looking for:
[IMG]http://i1298.photobucket.com/albums/...psqrlxfxvc.jpg[/IMG] |
Agreed with racing97. Use a junk cam tower to do most of the work for you. All you need is a plate to connect the hunk of cam housing to the lathe.
https://www.youtube.com/watch?v=XE2M2UUq_Ww I have a junk housing if you need one. edit............ Even creative John at Costa Mesa R&D uses the tried & true hunk 'o housing https://www.youtube.com/watch?v=dncyBPHCKyQ |
Thanks Kevin, that's a clever solution to this, will keep that as a plan-B. My plan-A is to use a steel disk I have that suits my Lathe well...will give very high precision I think, just needs to drill the needed holes in it.
Robert |
You will need some lateral adjustment some years are not concentric to later years centering will be an issue if you make it solid to the lathe.
| All times are GMT -8. The time now is 02:58 PM. |
