-   -   3.0 to 3.2ss questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/885736-3-0-3-2ss-questions.html)
mreid 10-05-2015 05:31 AM
I'm in the process of building my 3.2ss and have a couple of questions:
1. Wayne's book says no head gaskets, but that doesn't seem right. With 98mm cylinders, which head gaskets should I use (assuming I should)?
2. Should I torque heads then cam towers or cam towers then heads?
3. What is the best approach for removing sealing residue from cam tower (tower to head)?
4. Am I the only one who hates the piston pin wire locks?
Thanks all!
Flat6pac 10-05-2015 05:52 AM
No head gaskets, that's why EBS wants Carrera cylinders. SC cylinders runs out of wall by the time your head gaskets ridge is almost at 98 mm.
My preference is lay the 3 heads on the table, spray all sealing surfaces with carb cleaner, blow dry.
574 on the cam tower, place tower on the heads, bolt up. Install cam and rockers, adjust rockers by turning cam bevel to relationship to the crank. Reminder, cam turns CCW in the running engine.
Do next set
When installing I back crank about 40 degrees from Z1 to pull all Pistons down inside. Have the cam bevel cut up.
Torque heads to Carrera specs
The total answer to the circlips is the Stompski racing installers. You only need 22 and 23 for the 911, 22 for the SS.
Bruce
Flat6pac 10-05-2015 05:59 AM
Pics
http://forums.pelicanparts.com/uploa...1444049837.jpg
http://forums.pelicanparts.com/uploa...1444049956.jpg
mreid 10-05-2015 04:29 PM
Thanks, Bruce. I noticed that Pelican sells head gaskets for a 3.0. What gives?
Flat6pac 10-05-2015 04:40 PM
The 3.0 uses head gaskets and 25 ft# of torque. The Carrera uses a taper cylinder seal surface so the torque is 15# torque then retorque and 90 degree swing.
That's why you needed the Carrera cylinders because they can open the cylinder and not loose the sealing surface.
Bruce
gtihop 10-06-2015 07:35 AM
do you use sc heads or carerra heads when making a 3.2 ss. from a sc. 3.0 ?
Flat6pac 10-06-2015 07:57 AM
You use heads to match the injection. Carrera heads are ported too large for CIS so you have to find insulators that match the injection to cover the Carrera head ports.
Bruce
mreid 10-06-2015 04:38 PM
These are a perfect fit, but which ones are they?
http://forums.pelicanparts.com/uploa...1444174713.jpg
Flat6pac 10-06-2015 05:18 PM
Cross reference the K1826c. That will tell you what the head casting started as
I ll look to see if I still have the reference sheet here.
Bruce
KTL 10-08-2015 01:37 PM
Tom Butler here on Pelican has collected part number data over the years and he posted this head cross reference. Unfortunately your casting number and K number don't appear in his list.
http://forums.pelicanparts.com/uploa...1444336375.jpg
But based on the date of your heads (5-82) it would appear they are small port SC heads (1980-83)
Here's a picture of the SC cylinders (with ring gaskets inserted) and you can see how thin the cylinder wall is after they've been bored to 98mm
http://forums.pelicanparts.com/uploa...1444336512.jpg
edit...... I take that back. the chart indicates yours are 80-83 heads. K numbers is on the chart but not the casting
fred cook 10-09-2015 12:10 PM
Short stroke engine build
When I built my 3.3SS engine, I used Carrera heads and an early CIS air box with the 39mm runners. I had to open up the ends of the runners by 3mm to match the intake ports. I used a set of the Carrera intake spacers with the injector notches closed up with JB Weld. Along with the early SC airbox, I used the CIS hardware from a 1980 SC. I backdated the CIS layout to mimic that of a 1973.5 system. I also added a contact switch that will activate the cold start valve to richen the mixture at full throttle. Sounds really Rube Goldbergish, but it works quite well. Starts easily, makes good bottom and mid range torque and pulls strong to the ignition cutout at 7500 rpms. Speaking of ignition, I used the Electromotive XDi system to fire twin plugs per cylinder. Good luck with your build and don't be afraid to try something different!
mreid 10-10-2015 03:50 PM
Got the cam towers and cams installed.
My sc heads were ported and polished to 40/38, so they are twin plug Carrera spec. With the DC80 cams and PMO carbs I'm hoping for big numbers.
jpnovak 10-10-2015 04:15 PM
Hurry up and get that thing built and installed in the 904 already. I need an excuse to come down and drive it.
mreid 10-10-2015 08:23 PM
You are second in line, only to me!
mreid 10-11-2015 06:49 AM
How easy should the cams be to turn by hand? They went right in when I installed them. I can turn them with the sprocket flange installed (the smaller flange that fits over the woodruff key), but it takes a little effort.
Flat6pac 10-11-2015 07:27 AM
You have the 4 bearing, needs oil but there is resistance.. Use the bolt on the end to turn with.
Wait til you have rockers in place. I just put together heavier springs in a set of heads. Machinist said they were 40# heavier..noticeable difference on how I load up the sub assembly
Bruce
jpnovak 10-11-2015 11:42 AM
Did you use assembly lube or oil on the cam journals? assembly lube usually has a decent amount of viscosity drag. Should be able to turn but won't spin free.
mreid 10-11-2015 12:34 PM
Assembly lube. They are exactly the same on both sides. Went right in, but tough to turn. I'm going to shoot some oil in the spray bars and see if that makes a difference.
mreid 10-11-2015 03:08 PM
Made a small difference, but I must be an idiot.
I'm trying to time the cams and get to the point where I pull the pin and rotate the cam to hit the correct overlap. Easy, right? No. I have the newer style cams with the bolt and heavy washer. I need to turn the cam CCW. There is nothing to grab on to. How do I turn the cam while keeping the sprocket in place (I have the tool that holds the sprocket)? Thanks.
Never mind, I just figured it out. Actually easier than the old version. Now I just need the spec...
Flat6pac 10-11-2015 04:29 PM
I sent you a PM
Bruce
mreid 10-12-2015 12:11 PM
Got them both within the spec of 5.6, just over slightly when I rock back and forth. Reinstalled the tensioners and after lunch I'll install the rest of the rockers and adjust the valves. Thanks for all your help, Bruce! You have been an incredibly asset.
cgarr 10-12-2015 12:31 PM
Were your heads surfaced? they look like it so should all be level: to avoid cam binding all heights must be the same, is that the problem your having? cam turning hard after torqued?
mreid 10-12-2015 12:56 PM
They were. Once I got some oil in there I could turn them by hand with some effort.
jpnovak 10-12-2015 01:33 PM
Mark,
My method for timing the new bolt style cams is to use a small drift and place it in an adjacent hole. Use the drift to pry the outer cam sprocket against the inner lock sprocket. You can use the drift to either side of a center tooth depending on location. This allows you to spin the cam in either direction to get the desired lift.
The early style cams are much easier (IMO) to adjust since you just turn the actual cam.
KTL 10-12-2015 02:23 PM
The bolt-end cams can be turned with the bolt head. You just have to strategically put the bolt in the cam at the right time, w/out the big fat washer in place. Basically you use the specialty counterholding tool to hold the cam (obviously the indexing hub, sprocket and pin must be in place) and snug the bolt into the cam snout enough to create a bit of thread interference like double-nutting. Then pull the pin and rotate the cam as desired to change the TDC overlap lift. Hold the cam with the nut, put the pin back in, put the sprocket holding tool in there, remove the bolt so you can install the big washer, put the bolt back in snug, rotate engine 360 degrees and check your lift spec. Repeat as necessary.
cgarr 10-12-2015 06:30 PM
And an old spark plug works good to pull the pin!
Tippy 10-12-2015 06:49 PM
Originally Posted by jpnovak (Post 8833113)
Mark,
That's exactly how I did mine.
Tippy 10-12-2015 06:50 PM
Like a champ
mreid 10-12-2015 07:05 PM
I have a mini-slidehammer tool to pull the pin (the modern gear head can't have too many gimmicky tools). I made most of my tools, but this pin puller work great when the pin is pinched tight. I ended up cranking the bolt down and then (without the washer installed) I was able to make small adjustments in either direction until it was perfect.
