rsr distributor cap for Andial twin plug
Does anyone who anything about this cap, rsr distributor cap on ebay. I've seen a couple of listings for this.
I'm chasing down a high rpm miss in my 930 3.5 twin plug currently running an Andial RSR 12 plug distributor. The cap & rotor have about 13K miles of use. This uses the black cap. |
This is a Marelli Cap as fitted to the Maserati 3500GT and to the 911R on the S121A Distributor and the 2.8RSR with a Marelli S121B Distributor.
They have been re-manufactured by the Maserati Club International for the last few years along with a compatible Rotor Arm. They are normally about $270 so $200 is not a bad price. I believe that the Andial Dizzy Conversion used a 3.0RSR Dizzy cap which is Bosch rather than Marelli and is potentially incompatible with the S121A & B Type caps. The last time I spoke with Andial they had both black and Brown Caps in stock and on special offer. The Bosch Cap is 3 lug but I am not sure if the diameters and heights are the same as the Marelli and it is an expensive experiment to find out. RSR911.de in Germany make a replica Bosch 3.0RSR Distributor with cap and rotor but I am not sure if they sell caps and rotors separately. If you have a Marelli dizzy you can also fit a late Jaguar XJ12 Cap but you will need a different rotor which I believe can be obtained from Burnham Performance. Jag caps can be had for around $75 |
Thanks, I have the 3 lug Bosch. I didn't know I could still gets parts from Andial. Anyone know what the life expectancy of the cap & rotor are. They were installed in '06 by Andial, and have about 13K miles. I paid about $1100 for the cap & rotor back then.
Andial is LONG out of business, now.
Porsche Motorsports bought the name so if you need the Bosch RSR cap and/or rotor, you might contact them to see if they can source them for you since Bosch Motorsports no longer has them. |
I have a few NOS caps & rotors if needed.
http://forums.pelicanparts.com/uploa...1444327860.jpg http://forums.pelicanparts.com/uploa...1444327880.jpg |
...wonder if somebody has 3D printed one yet? |
This guy seems reasonable (relatively speaking). shop
My goal is to sort it out, then swap over to a Electromotive XDI. |
| All times are GMT -8. The time now is 04:31 AM. |
