Temperature - engine shroud
Hi folks, I'm making small repairs and possibly painting my "plastic" shroud . The materials I'm using withstand up to 150 degrees c. Is this okay for the shroud ?
I realise for other areas it might get hotter. Thanks very much Sent from my iPhone using Tapatalk |
I should have said it's a 3.0 SC engine
Paint the outside, not the inside. Research the prep to see what others have done to keep the paint on.
Bruce |
Thanks, I'm happy I can get the paint to stick it's purely the temperature I'm interested in. I'm also using a small amount of resin to repair a tiny area so I'm just trying to get an idea of temperature of the fibreglass shroud when hot....
Base coat clear coat, no problems .
BTDT |
| All times are GMT -8. The time now is 11:39 AM. |
