-   -   Need help identifying 98MM pistons (http://forums.pelicanparts.com/911-engine-rebuilding-forum/887150-need-help-identifying-98mm-pistons.html)
KTL 05-31-2016 06:30 AM
That's the fattest area of the piston to remove material for lightening them. And since aluminum alloy is pretty light, you have to remove a sizeable area under the crown to have it add up to several grams.
