-   -   Tolerances for boring barrels (http://forums.pelicanparts.com/911-engine-rebuilding-forum/888087-tolerances-boring-barrels.html)
obrut 10-21-2015 06:53 PM
Hi all,
I'm planning on having some 80.0mm 2 litre barrels from a 67 911 bored out to 81.5mm.
Does anyone know the tolerances I should provide to the machinist?
Steve@Rennsport 10-21-2015 11:22 PM
Clearances depend on what pistons you will use,... .:D :D :D
obrut 10-22-2015 12:31 AM
Thanks Steve - pistons are 9.8:1 JE's.
Henry Schmidt 10-22-2015 03:25 AM
Bore to 81.47mm and hone to the desired tolerance. If 81.5mm if the pistons are perfect. We like to size each piston.
All piston manufacturers build their desired clearance into the piston.
If everything was exact you would bore to 81.5mm. Then the JE would fit perfectly but nothing is exact. Each piston and each cylinder will have a tolerance. If your machinist can hold a .0005 that's about as good as you could hope for.
JE uses a .0015-0025" depending on the diameter and cylinder material.
obrut 10-22-2015 03:01 PM
Thanks Henry, much appreciated.
ajwans 10-22-2015 09:31 PM
What's the opinion on clearance for Mahle forged pistons? 80.5mm diameter.
andy
304065 10-23-2015 05:37 PM
Of course you must measure.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/368320-jugs-slugs-confessions-je-piston-owner.html
