IMR-Merlin's Avatar
Ruf 3.4 P&C piston slap
Hi all,
I have a built engine with Ruf 3.4 P&C installed. I have a rap that is throttle (engine load) based. It comes on at light throttle and can be held through out the rev range until I add power or reduce power. I am leaning toward piston slap and have heard that some or the Ruf 3.4 pistons were short skirt and prone to this. Anyone on this forum have any input?
Thanks in advance
Brendon
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 11-14-2015, 09:25 AM
Indeed, the Ruf 98mm pistons had a shorter skirt than the regular Mahle ones and they do make noise; Due to piston rocking and higher ring wear, we don't due these in any engines.
Short skirt pistons can be used in street engines, however VERY careful design is required to prevent these kinds of problems.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-14-2015, 10:34 AM
IMR-Merlin's Avatar
I guess the next question is....
Rebuild or run it?
I have about 4k on it since tuning and the noise has not gotten worse.
Old 11-14-2015, 10:57 AM
IMR-Merlin's Avatar
That was a serious question. We first heard this on initial start up and pre-tuning. It is only there under light (maintenance) throttle and goes away toward WOT and decel.
So is the noise something that is lived with or is it safe to do a rebuild and change out P&C?
Old 11-14-2015, 04:31 PM
abit off center
cgarr's Avatar
Is it only when cold? does it go away as it warms up?
______________________
Craig
G2Performance
Old 11-14-2015, 05:02 PM
IMR-Merlin's Avatar
all the way through temp range, but I never get engine temps above 140-160 unless in traffic.
If these are the 3.4 short skirts, they're known for this. Just not sure if its a livable sound or I should pull the engine and mic the bore then look for pistons.
the car pulls like a monster and I have a GT35R with billet wheel for next year so i should be 500+ RWHP.
Old 11-14-2015, 05:25 PM
