-   -   Upgrading a 1970 911t (http://forums.pelicanparts.com/911-engine-rebuilding-forum/888601-upgrading-1970-911t.html)
dpetteng 10-26-2015 12:48 PM
So I just purchased a 1970 911t with matching numbers engine. From looking at the "t" versus the "E' and "S" versions, what is the fundamental differences between these engines and can they therefore, be upgraded?
I am guessing that the key differences are compression ratio, cam etc. Anything else?
Dave
Trackrash 10-26-2015 02:51 PM
T's had non counterweighted cranks, cast iron cylinders, and mild cams.
You should buy Wayne's "How to rebuild 911 motors" and Bruce Anderson's "Porsche 911 Performance Handbook". They have all the details.
Read my garage for my motor's mods.
dpetteng 11-04-2015 08:21 AM
So I read the book and it doesn't really touch on what you can do to upgrade form a "t" spec to an "e" or "s" spec.
Is it just a case of new barrels, pistons and cam?
bgyglfr 11-04-2015 09:16 AM
P&Cs and cams will get you close to an E I've done it and it's a nice upgrade. S Pistons with E cams make a fun motor. The counterweighted crank is a non issue unless you spend a lot of time at 8k rpm. Actually, many will argue that you crank will spin up faster because it's lighter. The only difference that can be expensive is porting the heads which again isn't necessary unless you plan on building a high rpm motor.
dpetteng 11-05-2015 08:38 AM
Fantastic, so any idea where I can get "S" P&C's and "e" cams?
bgyglfr 11-05-2015 01:42 PM
What are your T cylinders like? You can reuse them and just buy some JE pistons. If the cylinders are bad just get 85mm pistons and have your cylinders bored to match. Your cams can be re ground to E or you can source a set. Pm me if you want. I will send you my number.
speedo 11-05-2015 06:15 PM
Keep your 2.2 P and Cs
They are high compression compared to the 2.4 gear. Best bang for the buck is to stroke the engine to 2.4 by swapping out the crank and rods. A 2.2 T engine will basically become a 2.4 E engine. I kept the T cams as E cams didn't give me comfortable valve clearance. The books talk about the benefit of the 2.2 T-E-S pistons. Bumping the 2.2 S pistons into a 2.4 with a 70.4 crank and rods is the real deal...but the 2.2 T in a 2.4 configuration is pretty sweet too.
Just say'in... :)
Speedo
bgyglfr 11-05-2015 07:17 PM
Speedo,
Good point. That would be a good option as long as you are splitting the case. Nice torquey street motor. The OP just asked for upgrade options. I assumed he wasn't planning a full rebuild.
Dave,
Are you planning a rebuild or just want some more pep out of your motor? Top end upgrade can be done for $1500-$2000. A full rebuild can be 4 times that. Especially if the case needs work.
safe 11-06-2015 03:59 AM
Don't forget that you need to re-jet the carbs. Unless you really want a E or S clone and get the correct MFI (mega bucks these days).
dpetteng 11-06-2015 06:49 AM
So I am going to have it torn down anyhow but its a matching numbers car so I don't want to bastardize it too far. To be honest I want more than 125hp in an engine that has some sense of being original, make sense?
safe 11-06-2015 07:04 AM
S P&C, E-cam and modified carbs. It will be a sweet street engine and I don't think anyone (future buyer) will mind or even notice if you don't say anything.
dpetteng 11-12-2015 05:39 AM
So I am stuck between a set of "e" NOS barrels and Pistons I have found and having my Cast Iron cylinders bored to 85mm and have JE Pistons.
I can see that "e" P&C's come out at 9.1:1 compression and JE's are 9.5:1.
As I am going to using this in the UK where higher rated petrol is available, should I go for the JE's as detonation is less of a problem?
Dave
bgyglfr 11-12-2015 09:14 AM
9:5-1 shouldn't be an issue on quality pump gas. If cost is the same, I would go with the NOS P&Cs. Just read a thread on JEs with cast pistons that you might want to take a look at before making your decision. A third option is to give supertec a call. They have several options of P&Cs available.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/890612-je-pistons-cast-iron-barrels.html
Trackrash 11-12-2015 09:15 AM
A friend of mine has S pistons in his 2,2 E motor. 9,8 to 1 CR. No problems so far with the crap they sell for gas in CA. It is a sweet running motor.
He also has Webers. You will need to do mods to your Zeniths to gain any power from any other improvements you make.
dpetteng 11-12-2015 10:51 AM
So you can slot in 2.2S pistons and barrels with a "e" cam?
Is there much you can do with Zeniths? Obviously not as many options as webers but I really want to keep the originality of the engine and not swap out the carbs. That's really why I was thinking of "e" barrels and pistons as I am not sure I can make the Zeniths gain the benefits of "s" components?
Trackrash 11-12-2015 12:12 PM
No problem with S pistons and E cams. The S cams have more lift and duration than the E cams.
I think with just the increase in CR and change to E cams the Zeniths can be made to work. In your case, you would need to go to larger venturis, probably 30mm would work. Then getting the jetting right. There are a couple of threads on building up Zeniths here on Pelican.
FWIW, I found the the Zeniths were better than the Webers on my stock 2,2T. Once I went to a 2,5 with 90mm P&Cs I could never get them to work right. If you are not increasing the displacement much, you should be fine with the Zeniths.
There are those who claim to have Zeniths working on 3,0 motors, I have read.
dpetteng 11-12-2015 01:56 PM
Great, any idea where I can get bigger venturis for the Zenith's? Can't seem to find any.
bgyglfr 11-12-2015 06:21 PM
You can get your venturies machined to spec. It shouldn't take much since you are just moving up one cam size. I think others have found them from performance oriented. Some will even argue that zeniths are superior to webers once you get them set up correctly.
speedo 11-12-2015 06:33 PM
2.2 stroked to 2.4
Not to beat a dead horse...if you are going to open the case, swapping the cranks and rods is easy. Keep the same P and Cs and cams. Keep the Zeniths. Stock chokes are 27s (I think) and you can find 28.5s. Engine and carbs look factory, yet you will have 175 hp vs 140 hp. Or, you can buy all the other stuff to improve performance...P and Cs, cams etc $$ and still not have a stock engine. KISS is how I think of projects...what is wanted/needed/necessary.
Just say'in.
Speedo
tharbert 11-13-2015 07:11 AM
A couple points...
Mag cases have their own challenges once you crack them open. Be prepared for a significant machine shop bill: case halves decked and align bored, spigots leveled, time serted head and select internal studs and the while-you're-in-there stuff like oil bypass mod and piston squirters. Mag cases tend to warp when taken apart and reassembly without the machine work may become problematic: stuff simply won't line up. Do a quick search about mag cases and head studs.
There is another conversation about P/C upgrades running close to this thread talking about JE pistons and cast cylinders. It's possible but not recommended mainly because of the difference in expansion coefficients between aluminum pistons and iron cylinders. It's something about which you certainly need to do your homework. It may be better to shop around for a full set of P/C's. There's a reason why they moved away from cast cylinders: they don't dissipate heat as well as the newer options. Heat is not a friend of these old Mag cases.
porschetub 11-13-2015 10:06 AM
Look for seller on Ebay Alfa1750 she has them CNC made in a good range of sizes,30mm is considered correct for your engine size,by the way the same seller has good rebuild kits,jets and can source other parts also,very good to deal with and fair prices and shipping,ask me how I know;).
Personally I never considered boring out my stock vents as they don't fit in a lathe well its just not that easy.
bgyglfr 11-13-2015 03:39 PM
I don't think it's automatic that mag cases need extensive machine work just because you split it for rebuild. Unless it has been exposed to significant heat (2.7 with reactors or racing) I wouldn't just assume it's automatically going to need a line bore Etc. Also, if you aren't building a high performance motor, the piston squirters and a lot of the race mods aren't necessary either. These 2.2 motors were pretty durable just the way they came out of the factory. It's when they stroked them to 2.4 and especially 2.7 when the cases started to be over stressed. I will give in to the oil bypass mod and case savers but those are pretty inexpensive.
tharbert 11-13-2015 05:44 PM
Originally Posted by bgyglfr (Post 8876609)
I don't think it's automatic that mag cases need extensive machine work just because you split...
It's common enough for Dave to know it should at least be evaluated. Trying to reassemble a warped case is probably extremely exasperating and will undoubtedly leak like a sieve. Nothing I mentioned is considered a "race mod." Piston squirters were added in 1972 to even the lowly T model and is a desirable mod for a more bullet proof engine, not to make it rev higher...and it's fairly inexpensive. We certainly agree on the head studs.
bgyglfr 11-13-2015 06:56 PM
True. Piston squirters are inexpensive as well. I suppose that alone would justify going ahead and getting it done. I guess my point was that more often than not, a 2.2 will come apart without warping. To me they get lumped in with the 2.7 motors that were exposed to much more heat.
SWS911 11-13-2015 10:22 PM
Case/Piston squirters were added in the '71 model year. If you change cams don't forget about changing or altering your distibutor to match. You should have a Marelli for that "T" Try and find the proper Bosch 008 for the "T" cams or the 006 for the "E" cams and the 007 for the"S" cams.
dpetteng 11-14-2015 01:25 PM
Great input guys. Any idea where I can get the right distributor for "e" or "s" cams?
bgyglfr 11-14-2015 04:02 PM
Post a wtb here. You should find one between $3-$400.
tom1394racing 11-15-2015 04:46 AM
You can have your Marelli rebuilt and recurred to match your other modifications. Contact Kurt at Parts Klassic
