-   -   How do you separate cases when jugs rusted (http://forums.pelicanparts.com/911-engine-rebuilding-forum/888710-how-do-you-separate-cases-when-jugs-rusted.html)
Sperryfish 10-27-2015 11:34 AM
I've dismantled an old 1969 911 engine and got it to the cylinders and cases stage. I can't get any of the pistons to move so I have no way to separate the cases.. Any advice??
Thanks....
lrodri64 10-27-2015 07:49 PM
I saw a picture the other day on which the owner cut the cilinder with a grinder.
SoyRacer 10-27-2015 08:19 PM
I use a hole saw. Start it on center with the pilot bit, get the saw cutting, remove the bit and then cut down - through the piston - and around the wrist pin. A 3" hole saw usually does the trick.
tom1394racing 10-28-2015 05:05 AM
I have had to do this several times. I use a die grinder with a heavy duty cutting wheel to cut a slot about 3/4 of the way down the cylinder being careful not to damage the case or the piston. I then use a chisel and a heavy duty hammer to split the cylinder open from the top. This frees the cylinder from the piston and allows the cylinder to be removed from the case, usually in several pieces. Most times it is not necessary to do this on every cylinder as only 2 or 3 are usually the offending stuck ones.
mattC2993 10-28-2015 05:17 PM
I had to split all 6 of the cylinders on my 2.2 using an angle grinder with a thin cutting disc. I used a pry bar to separate the piston from the cylinder. It was a lot of work but I managed to save the pistons only to find out that all of the rings were stuck.
safe 10-29-2015 01:44 AM
If you tilt the engine on the side you could probably free the rings with phosphoric acid.
Sperryfish 10-29-2015 09:45 AM
Thanks...
I'm going to try some of the methods you described..
Thanks for the help..
bgyglfr 10-31-2015 07:56 AM
How badly are they rusted? I've been able to loosen them before by turning the engine on the side and soaking them with marvel mystery oil and then tapping them with a hammer and slide each cylinder off individually.
speedo 11-01-2015 07:38 AM
Kroil
Rotate the engine on its side and soak the P and Cs with Kroil. Vibration helps, and patience...is necessary. I just freed up a 356 engine that was partially submerged in a flood. A bet and beer was involved. Took two weeks, but it is now free.
Speedo
Lapkritis 11-02-2015 07:29 AM
Coca Cola ...
maybe add a little heat to the jug too.
bgyglfr 11-02-2015 07:59 PM
I once saw an old school mechanic use candle wak on bolt threads. The theory was that if you heat the bolt the wax would get sucked into the threads like solder and help them break loose. Never tried it myself.
924CarreraGTP 11-02-2015 10:58 PM
I think both kroil and/or phosphoric acid are both a good start. In a pinch I would resort to WD40 before getting any saws out. Saws get radical at times, but other times they are 100% needed. With that 2.2 I would be very careful and precise. Berrymans makes a very high grade chemical dip that works wonders on things like this. I watched it melt rust once in front of my eyes.
