-   -   Missing Parts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/889319-missing-parts.html)
DSPTurtle 11-01-2015 10:37 AM
Missing Parts
This is not what you expect to see this early in the tear down. i wonder if the original owner knew the motor was down on power. Haha
http://forums.pelicanparts.com/uploa...1446403021.jpg
silverc4s 11-01-2015 01:26 PM
Well, the cast iron rocker was designed to be the weakest link in the valve train, right? Looks like this one worked��
Flat6pac 11-01-2015 01:45 PM
You have it because the owner realized compression was low....
Bruce
Tippy 11-01-2015 03:21 PM
Hope you don't have a bent valve leading to shattered rocker.
DSPTurtle 11-02-2015 05:14 AM
I keep thinking I'm going to find it somewhere but no luck yet. Pretty much every fastener and cover was glued together on this guy so lots of patience to get it apart. I'll post a few more pics later especially if I find the rocker swimming through the motor somewhere.
DSPTurtle 11-07-2015 10:06 PM
Looks like #2 big end got a little warm...
http://forums.pelicanparts.com/uploa...1446962753.jpg
Cairo94507 11-08-2015 06:50 AM
Wow!
DSPTurtle 11-08-2015 11:01 AM
#7 main has seen much better days. Everything else shows normal wear. This little guy got abused!http://forums.pelicanparts.com/uploa...1447009266.jpg
Spenny_b 11-08-2015 04:31 PM
Christ almighty....what a train smash of an engine.
stownsen914 11-08-2015 05:36 PM
Wow that's impressive. Lucky the rod didn't exit the crankcase ...
afterburn 549 11-09-2015 12:37 AM
Motor mysters engine ?
