-   -   Please show me your engine drop stand (http://forums.pelicanparts.com/911-engine-rebuilding-forum/889437-please-show-me-your-engine-drop-stand.html)
911 Rod 11-02-2015 07:46 AM
Hey Gents,
Getting ready for my engine drop.
When using a lift, what is everyone using to drop their engine on?
I was thinking of using a engine cradle with plywood on top.
Dltjaden 11-02-2015 07:55 AM
I just use a furniture dolly. Under $10 at Home Depot or Harbor Freight.
911 Rod 11-02-2015 08:20 AM
Seeing that I have a lift, I was hoping to work a bit higher than that.
Dltjaden 11-02-2015 08:42 AM
Other options are motorcycle lifts and lift tables. HF has lift tables that support 500 or 1,000 pounds depending on the model. HF is ok for occasional use in this case.
'78 SC 11-02-2015 10:17 AM
You're right about wanting to work higher. I used an ATV jack with my MaxJax and had to keep the lift low. Negated some of the advantages.
I bought the HF 1000# table for my next engine drop. I plan to work out a mechanism to control angle to get the transmission in and out. More importantly a positive lock to hold the table up. That thing is one hydraulic leak from being a guillotine.
911 Rod 11-02-2015 12:45 PM
I was thinking one of these with a platform on top.http://forums.pelicanparts.com/uploa...1446497125.jpg
tocobill 11-02-2015 06:55 PM
HF lift table. Works well. Can also transfer the engine to stand instead of using a cherry picker.
1000 lbs. Capacity Hydraulic Table Cart
RedCoupe 11-02-2015 07:36 PM
It looks to me as though the engine cradle is using a V8 engine block for some of its structural integrity. It's probably plenty strong for the P engine weight, but I would weld a couple of extra cross members to keep the members from spreading apart when it is loaded.
911 Rod 11-03-2015 06:14 AM
For sure. I was going to run angle iron to join the posts. The beauty of this one is you can slide a jack into it if need be. Plus it's $40!
toddu 11-04-2015 04:26 AM
Bought one of these with the 20% discount. Works perfectly with my midrise lift. It's very heavy and stable.
Todd
bgyglfr 11-04-2015 05:52 AM
I have a four post lift. I just use some heavy saw horses and 2x4s. Then I use the lift to raise it off them for the engine stand.
Alexm930 11-06-2015 06:04 AM
http://forums.pelicanparts.com/uploa...1446818615.jpg
http://forums.pelicanparts.com/uploa...1446818638.jpg
911 Rod 11-06-2015 06:14 AM
^^^Nice
