-   -   3.8 application for 964 (1994) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/889751-3-8-application-964-1994-a.html)
993buyer 11-04-2015 09:32 AM
Hi,
Do any of you have experience with these?
Porsche 964 RS 3.8 102mm Pistons Cylinders MAHLE Bore In
There is also a slip in version available...what is preferred?
Thx
http://forums.pelicanparts.com/uploa...1446658227.jpg
Bill Verburg 11-04-2015 02:08 PM
Originally Posted by 993buyer (Post 8863762)
Hi,
Thx
The picture looks like cis pistons not the 102mm 964 RSR pistons, the 964 RS used the same 100mm p/c as all the other 964s
here is what the 102s should look like
http://forums.pelicanparts.com/uploa...1446674872.jpg
look for tapered wrist pins, coated skirts and the big valve pockets
964 versions and 993 versions are not interchangeable
These are heavy enough so the lighter tapered wrist pins are desirable, they also bump the cr a bit. Over all they work well w/ lumpier than stock cams
