-   -   Attaching crank to flywheel 3.6 rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/889989-attaching-crank-flywheel-3-6-rebuild.html)
JonT 11-05-2015 04:01 PM
Im about to attach the rods to the crank and to stabilize the crank I wanted to bolt these two up but there is a pin on crank that wont fit into the flywheel so it wont sit flush. Is this pin supposed to fit in the flywheel hole? Thanks
mreid 11-05-2015 04:11 PM
There should be a pin hole in the flywheel that mates and orients the flywheel properly. Is this a new flywheel? Also, is this a 964 or 993 engine. It makes a difference.
JonT 11-05-2015 04:13 PM
964 flywheel and crank. the pin seems to be slightly too large for the orientation hole. thanks
mreid 11-05-2015 04:28 PM
the pin is kind of tight. You should be able to get it started and snug it down with a few bolts.
JonT 11-05-2015 04:54 PM
thanks I'll try that I was laughing to myself as I failed at step one of the p-fix-it video which is attaching the con rods to the crank (sitting upright attached to the flywheel).
JonT 11-08-2015 08:11 AM
you were correct mreid the crank pin seated easily with the bolts tightened a bit thanks
