-   -   2.0 cam/crank clearances (http://forums.pelicanparts.com/911-engine-rebuilding-forum/890908-2-0-cam-crank-clearances.html)
calcars1 11-12-2015 02:19 PM
Hi
I have a 68 bare case
what should my cam and crank clearances be?
thanks
Steve@Rennsport 11-12-2015 04:37 PM
I'd kindly recommend buying some books if you are going to tackle this job. There are far too many variables at work here.
FWIW,....the 911's cams are SOHC so this means they are not in the engine case.
