How to compress chain tensioner to install
I'm trying to replace a chain tensioner, I compress the piston slowly with C clamp, but as soon as I remove piston pops up immediately.
How do I get it to stay so I can slide it in |
You need the little pin that holds it in place. I made mine from 1/16 music wire. Coat hanger wire would be ok.
There is a hole the wire goes into. Piston has to be in almost the entire way. New tensioners come with the pistons retracted and a nicer pin |
Cotter pin or finishing nail will also work.
Cheers |
Or Allen wrench
I used an Allen wrench as well.
| All times are GMT -8. The time now is 06:18 PM. |
