-   -   Cam Timing 73.5 CIS Stock Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/893642-cam-timing-73-5-cis-stock-rebuild.html)
ahklein 12-03-2015 06:54 PM
Can someone help with the valve overlap needed for my 73.5 CIS stock rebuild?
Thanks!
ahklein 12-05-2015 12:48 PM
Thanks to Henry Schmidt at Supertec Performance, the answer is 0.9-1.1mm. He knew the answer right off the top of his head, but verified it.
Thank you!!
boyt911sc 12-05-2015 02:05 PM
Stock camshafts specifications......
Thanks!
ahklein,
The stock camshafts specification is well documented in Wayne Dempesey's 911 engine rebuild book. All you have to do is open the book on page #207 and refer to 1973 1/2 CIS camshaft. Hope you have Wayne's book as reference. And if you don't have one, time to get one for X'mas.
Tony
