Quicksilver914's Avatar
Motec WIring Harness?
Anyone aware of who is building Motec harnesses for race car applications?
Old 12-07-2015, 05:10 PM
Kartoffelkopf
Spenny_b's Avatar
Can put you in touch with somebody in the UK who makes very nice harnesses; being in the US it's probably not your first choice, I'm sure, but not beyond the realms of possibility if you can give accurate dimensions, and supply specs for whatever sensors you're running.
Uses full Raychem wire and sleeving, and if required will use MIL spec connectors...all fully epoxy bonded, etc, etc.
Does looms for the likes of MoTeC, Life/Syvecs, MBE plus British Touring Car stuff (where allowed, they're a controlled/supplied item, AFAIK)...He's also a lot more reasonable than other mainstream motorsport harness manufacturers like Lake.
ETA - I'm sure Chris @ TurboKraft still sells MoTeC, obviously a lot closer to you, so may be worth a call into him - sure he can supply one.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 12-09-2015, 04:38 PM
The absolute best in the business is Sakata Motorsport Electronics
Sakata Motorsport Electronics, Inc.
regards
Old 12-09-2015, 06:32 PM
Motorsports Electronics | MoTeC | AEM | Autosport | Raychem | Tefzel in Huntington Beach make excellent harnesses as well, very high attention to detail and vast experience with Motec products.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 12-10-2015, 08:12 AM
