-   -   New Camshaft - looks used / previously installed -send back? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/894544-new-camshaft-looks-used-previously-installed-send-back.html)
0396 12-10-2015 08:08 PM
I just bought a set of new Camshaft from dealer.
One camshaft was package in a plastic bag. The other was not and it had some ones dirty hand marks on it.
On one end of this camshaft, looks as though it was installed and removed. Question is if I do keep this camshaft and based on the pictures, should I worry or simply return for another camshaft?
Thanks in advance for your advice. http://forums.pelicanparts.com/uploa...1449806744.jpg
http://forums.pelicanparts.com/uploa...1449806811.jpg
http://forums.pelicanparts.com/uploa...1449806910.jpg
Reiver 12-10-2015 08:28 PM
If I pay for new I want new...not almost new. Call them up, send them the pics. They may have made a mistake.
Jeff Alton 12-10-2015 08:32 PM
They look new, that dull color is parkerizing to protect them at start up.
0396 12-10-2015 08:33 PM
Thats my thinking too. I just wanted to see what the engine experts had too say. ..Current stock in Germany is only 2 available -:(.
Thanks for your response.
0396 12-10-2015 08:35 PM
The area that looks used previous install is 1) not in a plastic bag like the other one 2) the hand marks on the box and non factory tape.
Reiver 12-10-2015 08:43 PM
The top pic has the finished removed as if it had been installed and turned....why it was installed/removed would be my concern. Could be fine, but I'd inquire.
0396 12-10-2015 08:55 PM
I don't think anyone can answer that question as it came from the Porsche parts depot in Germany.
I think someone order it installed it and returned it to the dealership in Germany. Again, my thoughts are - if I order and pay for a new camshafts, I expect them unused. But due to the low stock in Germany, I figured I should inquire here.
tom1394racing 12-11-2015 03:48 AM
Looks unused to me.
0396 12-11-2015 06:17 AM
Tom,
I respect your opinion, but how about the shiny part on the front of the camshaft. ..where it looks like it was installed and turn without any lubrication. Is there any concerns there? Thanks
tom1394racing 12-11-2015 06:46 AM
Originally Posted by 0396 (Post 8913543)
Tom,
I am not sure where the "shiny" part you are referring to is.
0396 12-11-2015 06:48 AM
Its on the first picture near the nose of the camshaft.
Should I be concerned with that area?
Reiver 12-11-2015 04:21 PM
The finish is worn off near the bearing surface and nose...the only way to do that would be mounting I'd guess....altho it doesn't look run, just turned.
gtc 12-11-2015 04:22 PM
As long as it's straight, I wouldn't worry about that area you're talking about. Could just be from factory checks.
There are other factory parts that come with marks on them... rod bearings come to mind.
0396 12-12-2015 02:53 PM
Thanks for all the replies. I wanted new and paid for new, so this camshaft in question is on its way back to the dealer for replacement.
klefroid 12-16-2015 10:14 AM
I would do the same, If you install this one you end up in a new rebuild after few day's
