Does someone have a diagram of a 3.6 crank?
I want to make sure I have the rod journals and main journals labeled correctly. Thanks
Bonus question--how did you label the rod bolts when you measured them prior to installation (to check for stretch) for future reference in case you ever needed to reuse them (ARP)? |
The spec is the same as a 3.2 except for forward of #8
Bruce |
Thanks Bruce but I'm not familiar with a 3.2 crank either. Im just looking for something really simple ei. an arrow "this is the no.1 rod bearing" or "this is the no. 4 main bearing".
#1 main is a heavy oil feed bearing to the rods as is #8. #1 starts at the flywheel through #8 is the solid Nose bearing.
Starting at 8 the first throw for the rod is #4, then #1, #5, #2, #6, #3. Bruce |
The machinist that resized my rods scribed a number on the head of each bolt.
| All times are GMT -8. The time now is 03:26 PM. |
