rebuild kit for Webers
Rebuilding a set of Weber carbs off a 71T, Pelican has two different kits available but, unsure on correct kit I should use.
p/n: 901-108-948-00-WPC p/n: SIC-100-948-00 http://forums.pelicanparts.com/uploa...1451175524.jpg |
We only use the kit offered by PMO. Richard has taken the time to sort through the miscellaneous supplier to piece together a best parts available.
If Pelican sells that kit, buy it. If not 911 Vintage Parts has them in stock. Ken @ 760-731-4911 |
+1
| All times are GMT -8. The time now is 08:38 AM. |
