-   -   Which lube for valves guides? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/896419-lube-valves-guides.html)
VFR750 12-28-2015 07:25 AM
I'm rebuilding my heads. Which lube is recommended for the valve when installing it into the guide?
I was thinking the moly assembly lube used for the crankshaft and rod journals would be ok.
Just not sure if the hot, sliding environment would need something different.
cgarr 12-28-2015 07:34 AM
I do a 50/50 mix of torco assembly lube and motor oil
