-   -   3.6 conversion issue (no fuel) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/896420-3-6-conversion-issue-no-fuel.html)
safe 12-28-2015 07:28 AM
I'm installing a 964 3.6 engine in my -69 car.
I've made the conversion harness myself and all other wiring, but the engine won't start.
*I have spark.
*I have fuel pressure
But the injectors don't fire.
It like the DME is cutting the fuel on purpose. Have I forgotten something. Is there any "safety feature" that cuts fuel that I might have missed?
Any ideas?
safe 12-29-2015 11:58 AM
This is getting really annoying.... Been over everything...
The last thing is the battery and voltage drop. The voltage drops really low, 8.5-9.5 volts when cranking.
Anyone who knows how low it can drop and the dme still work?
porterdog 12-29-2015 01:06 PM
I've seen the electrics in my 964 flake out after it sits too long in the 'run' position without actually running, but I have to imagine that the drop-during-cranking was something the designers expected. Are you running a modern-sized battery? I have a hard time imagining a 1969-sized battery could effectively spin a manly 3.6.
Do you have access to a Bosch Hammer or analogous (Durametric, etc...) scanner to watch what's occurring in real-time?
Pellesin 12-30-2015 11:33 AM
Just a far out tip: a friend of mine struggeled with hes car for quite some time until he finally found out that he'd mixed the wieres to the injectors. + on - and vice versa. It's far out - but will really be confusing if it's wrong..
safe 01-01-2016 01:55 PM
Success! Today it started up!!
Could not believe it all 6 injectors were stuck closed!!
I connected 12v directly from the battery, that freed them up and they started to "click".
