-   -   Weber Engine Cut Off (http://forums.pelicanparts.com/911-engine-rebuilding-forum/896545-weber-engine-cut-off.html)
pemz0r 12-29-2015 09:13 AM
I started to experience an issue with cold starting. When the engine turns over it starts up and idles fine, but once I give it gas the engine will die. Any ideas?
Steve@Rennsport 12-29-2015 10:42 AM
Check your fuel pressure, float levels and accelerator pump volumes.
SoyRacer 12-29-2015 05:13 PM
Simple - Sell them and buy a set of PMOs ����
pemz0r 12-30-2015 12:28 PM
fuel pressure is at 5psi. If I am going to check the float levels and Acc pump shouldn't I just rebuild/clean them, since they have to be removed?
Walt Fricke 12-31-2015 11:05 PM
Isn't the fuel pressure spec for Webers 3.5 psi?
Steve@Rennsport 01-01-2016 09:28 AM
FAR too high; fuel pressure MUST be 3.5 psi for Webers. Once you adjust that, reset all your float levels.
