-   -   what injector size / 79 3.0 big port EFI (http://forums.pelicanparts.com/911-engine-rebuilding-forum/897494-what-injector-size-79-3-0-big-port-efi.html)
jimtweet 01-05-2016 06:16 PM
I am in the process of starting a EFI project on my 79 3.0L big port.
Anyone have insight to what injector size is a good starting point?
31LB?
31lb/hr (330cc/min) Magneti Marelli (Pico) - Fox Injection
46LB?
46 lb/hr (483cc/min) Magneti Marelli (Pico) - Fox Injection
al lkosmal 01-05-2016 06:45 PM
megasquirt:injectors [SymTech Laboratories]
here is a simple calculator for minimum size......
TimT 01-06-2016 04:47 AM
Yes just plug in the numbers on an injector selection calculator like the one above, or Marren has good one also..
https://www.injector.com/injector_selection_guide.html
chris_seven 01-06-2016 07:55 AM
http://i197.photobucket.com/albums/a...ps8q9uomrk.png
xbmwguy 01-06-2016 04:42 PM
also figure in type of fuel in the equation ;)
Tippy 01-06-2016 04:58 PM
How much power do you plan on? Mid-20's I'd think would be plenty.
chris_seven 01-07-2016 12:21 AM
Do you mean Methanol of other fuels with different energy ratings to normal gas?
I don't believe Octane Rating will change the energy produced although it may reduce compression and hence the horsepower developed which will be taken into account by all of the basic calculations.
