-   -   3.8 cayman (http://forums.pelicanparts.com/911-engine-rebuilding-forum/897931-3-8-cayman.html)
Jeff Alton 01-08-2016 09:31 PM
3.8 cayman
Although most of the is forum is dedicated to aircooled motors, here is a change of pace!
3.8 conversion on a 987.1 Cayman S. LN engineering sleeves, JE pistons, Schrick cams, IPD intake plenum, ECU tune and complete exhaust including catless headers...
Here is where it is at so far!
http://forums.pelicanparts.com/uploa...1452317385.jpg
http://forums.pelicanparts.com/uploa...1452317403.jpg
http://forums.pelicanparts.com/uploa...1452317428.jpg
And the reason it came apart in the first place...
http://forums.pelicanparts.com/uploa...1452317461.jpg
Cheers
mikedsilva 01-08-2016 11:31 PM
unhappy looking pistons...
0396 01-09-2016 08:13 AM
Cheers
Question, what in the world caused that? Lack of oil?:(
Jeff Alton 01-09-2016 08:25 AM
The scoring of the bores and pistons is becoming more and more common on M96/97 engines. The current theory is that the piston expands quicker than the block during a cold start and their is not enough clearance to accommodate this...
Cherers
preston_brown 01-09-2016 05:01 PM
And what are the symptoms?
Jeff Alton 01-09-2016 10:16 PM
You will see increased oil consumption and begin to hear a ticking sound similar to a failing lifter. The ticking and oil consumption will get worse as the scoring continues to develop.
Vizor 12-20-2019 06:45 AM
How did this build turn out? I'm specing out a very similar 3.8 conversion and was considering Schrick cams. Finding feedback or performance results on these cams by anyone has proven hard to come by. What HP/TQ did you get, swap in all new lifters, anything else?
Any feedback greatly appreciated.
