-   -   Cylinder Head use/ PC bores (http://forums.pelicanparts.com/911-engine-rebuilding-forum/898055-cylinder-head-use-pc-bores.html)
drumbraker 01-10-2016 07:55 AM
Is it possible to take a set of heads, previously used on 92mm PC and get them back on 84mm PC? ....Without reinventing the wheel.
My gut tells me, no. However you all are way smarter than I am.
356RS 01-10-2016 10:26 AM
That's going to be a challenge. You have about a 9.9mm difference. I suppose one could have a spacer made up to help keep the 84mm cylinder centered in the 107mm I.D. head bore.
