Turbonut
Raceboy's Avatar
Camshaft identification help needed (photos)
I bought a basketcase engine a while back and apparently it had completely different cams used, LHS is E cam (901.105.181.0R, NE stamped in front) and other seemed to be S profile, but lacked the S stamp in the back or front, but had 9.01 and 168.00 stamped in front and nothing in the back. Part number is 901.105.110.1R. Lobes measured like S cams (37.3 mm intake, 36.4 mm exhaust) and the profiles seem identical to S cams I have laying around (which do have "S" stamped in the back in the wankel-like triangle).
Now the question is, is the mystery cam really S cam or Solex or something else?
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 02-17-2016, 08:51 AM
Alan L's Avatar
try this
http://carquip.com/parts/911/engines/camtable/index.asp
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-17-2016, 10:56 AM
Turbonut
Raceboy's Avatar
Seems that the link is down...
Old 02-17-2016, 11:09 AM
Alan L's Avatar
I did a google with your cam number - it led me to a few threads. You may try that. I think your answer is in those threads - I just did the short cut with the link.
Alan
Old 02-17-2016, 11:15 AM
Turbonut
Raceboy's Avatar
Thanks. Googled it also before posting this thread, the results led me to confusion, hence the question
Old 02-17-2016, 09:20 PM
