-   -   2.7 E Weber setup (http://forums.pelicanparts.com/911-engine-rebuilding-forum/902286-2-7-e-weber-setup.html)
pemz0r 02-12-2016 05:02 PM
2.7 E Weber setup
I have been running this carb setup for about 6 months, and the car ran great, or at least what I think. Until I did some research and found out that the engine might be running lean.
CURRENT CARB SETUP
Venturis: 32
Main Jets: 125
Idle Jets: 60
Emulsion: F26
Air Correction: 180
MY ENGINE
2.7
E Cam
9.5:1
SSI
M and K Exhuast
The setup that ************ recommended was to run this, but I think the Air Correction seems low. Thoughts?
Venturis: 34
Main Jets: .145
Idle Jets: 60
Emulsion: F3
Air Correction: .140
Steve@Rennsport 02-12-2016 10:29 PM
Put 160 A/C's in there and you'll be good.
pemz0r 02-12-2016 11:12 PM
Steve,
Do you think 140 is too small?
pemz0r 02-19-2016 05:50 PM
I installed this combo
Venturis: 34
Main Jets: .145
Idle Jets: 60
Emulsion: F3
and the car felt very sluggish, so I decided to put in the AC at 180 and it improved but it doesn't have that "POP" from the previous setup
Venturis: 32
Main Jets: 125
Idle Jets: 60
Emulsion: F26
Air Correction: 180
I think I am going to go back to this and see if I can get that "POP" back.
Does anyone think they might know why it might not have that pop?
Steve@Rennsport 02-19-2016 08:00 PM
32mm vs 34mm venturies. :)
pemz0r 02-21-2016 05:31 PM
I reinstalled this setup
Venturis: 32
Main Jets: 125
Idle Jets: 60
Emulsion: F26
Air Correction: 180
and the car runs a lot richer and it has better acceleration then the recommended setup. How is that possible?
Venturis: 34
Main Jets: .145
Idle Jets: 60
Emulsion: F3
Flat6pac 02-22-2016 04:56 AM
The pop or back fire through the intakes usually means you're running lean.
Bruce
rennzeit 03-03-2016 12:09 AM
I think he meant figurative pop, like responsiveness.
The smaller 32 venturi gives a stronger vacuum signal to the main jets, pulling more fuel earlier in the revs. So even though the main jet is smaller, it is providing more fuel.
