Al S's Avatar
2.2 Intermediate Shaft Gear Wear - Opinions
The 4.5 diameter pin measurement passes, I measure 137.33 mm and the wear limit is 136.50 mm.
Have not checked backlash with the crank gear yet.
So other than the pitting...
Thrust side:
That is not a crack below, just more pitting.
Non thrust side:
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 07-14-2015, 07:31 PM
I am pondering the same thing with an sc. More worrying than the price of the gear is a statement that says gear and shaft were machined after assembly, or at least the gear was. So do I need a whole new intermediate shaft and gear? Also once the pits show is wear faster?
Old 02-18-2016, 07:52 PM
Check with a dismantler, I'm sure there will be many in stock, reasonably priced.
Just know the stamped number on the gear drive, 0 or 1.
Bruce
Old 02-19-2016, 01:12 PM
