-   -   factory manual image for rebuilding 930 tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/902765-factory-manual-image-rebuilding-930-tensioners.html)
wprater 02-16-2016 06:25 PM
I'm looking for rebuild/install instructions for the turbo chain tensioners.
I've got the rebuild kit 911.105.901.01 but the instructions I found don't have images and I can't recall where that little ball goes.
anyone have some images/text from factory manual for rebuilding these?
Alan L 02-16-2016 08:08 PM
I don't think the manual has any instructions for rebuilding them. The manual only has stuff specific to the 930. The tensioners are not unique to the 930.
Regards
Alan
Ronnie's.930 02-16-2016 10:50 PM
I found this by doing a google search for "930 cam chain tensioner exploded view" - not sure it helps you, though . . .
http://www.porscherepair.us/porsche-...e-oil-tank.jpg
wprater 02-16-2016 10:54 PM
[QUOTE=Ronnie's.930;9001098]I found this by doing a google search for "930 cam chain tensioner exploded view" - not sure it helps you, though . . .
that's the later style Carrera pressure fed tensioner. I like the "exploded view" keywords, will try that.
ajwans 02-17-2016 04:11 AM
I think this is what you are looking for:
http://forums.pelicanparts.com/uploa...1455711063.png
andy
wprater 02-17-2016 10:40 AM
thanks Andy! that's great, but I think that for an earlier version the 901 vs the thin boss late 930. it's missing the little spring to hold the ball.
do you have another ?
wprater 02-17-2016 11:04 AM
found it. would be nice it it had descriptions, like yours. so if you do have a copy, feel free to post it here! :)
https://www.dropbox.com/s/6w8npam9ms...jpg?dl=0&raw=1
wprater 02-17-2016 02:52 PM
here is a pic I took with the parts laid out. I'm rebuilding now.
https://www.dropbox.com/s/9fr6ddmwhe...peg?dl=0&raw=1
SexOnTheBeach 02-18-2016 06:15 PM
Good info!!
safe 02-18-2016 11:05 PM
This exploded view is in the Haynes manual.
Someone of the engine gurus here has also written an instruction, like 10-15 years ago. I remember that I found them when I did this.
wprater 02-19-2016 10:22 AM
I made this little M6 tool to help hold the plunger down
https://www.dropbox.com/s/1zr5ecgwb9...jpg?dl=0&raw=1
https://www.dropbox.com/s/3zncy2agkp...jpg?dl=0&raw=1
faverymi 02-20-2016 06:49 AM
[QUOTE=wprater;9004632]I made this little M6 tool to help hold the plunger down
Great info!
Is this the only special tool needed for the job? Besides the rebuild kit?
wprater 02-20-2016 09:44 AM
I also bent an old top spring which I used to push the little ball down. this allows you to continue to fill the chamber with oil until it's stiff. https://www.dropbox.com/s/vrmj66rlky...jpg?dl=0&raw=1
