-   -   cam timing tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/902873-cam-timing-tensioners.html)
Alan L 02-17-2016 10:58 AM
Any reason why you can't use the regular tensioners when doing cam timing? They must be as close as you can get to regular tension compared to the other tools.
Alan
Flat6pac 02-17-2016 11:24 AM
I use the regular tensioners all the time. As internal temps change so does the chain length.
Bruce
Alan L 02-17-2016 12:14 PM
I can't see why not. So why do people go to the trouble of vise clamps and special tension tools?
I just spent half a day making up a tool for the RHS :-(
Regards
Alan
john walker's workshop 02-18-2016 07:02 AM
As long as there is no slop in the tensioner.
Alan L 02-18-2016 10:14 AM
Presumably if they are doing the job in the engine, they will be adequate, slop wise, for cam timing?
Thanks john.
Alan
chris_seven 02-18-2016 10:15 AM
Excerpt from Vol.I of the Workshop Manual -
http://i197.photobucket.com/albums/a...ps6nhndj6j.jpg
Alan L 02-18-2016 03:31 PM
So, I just used the engine tensioner for the LHS. Worked fine, but there were a couple of issues.
1) If your lock pin ends up in the 5-7 o'clock position you struggle to get at it with a spark plug
2) I had to remove the tensioner again to torque the bolt. (not really a biggie)
I used my special tool for the RHS (since I spent half a day making it and that side has always given me grief tensioning). I have til now used Waynes methods which don't use the engine tensioner.
I can see there may be some advantages to not using the engine tensioner as long as you have access to other tools.
Regards
Alan
