-   -   Can Dilavar head studs be safely re-used? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/904939-can-dilavar-head-studs-safely-re-used.html)
Tippy 09-06-2016 10:06 AM
Originally Posted by Steve@Rennsport (Post 9026735)
The ONLY Dilavar ones I would re-use are the late 993TT full-threaded ones.
The rest go into the metal recycling barrel.
I reused mine due to your advise and have not had any problems in about 5 years of running knocking around 650 turbocharged hp.
Henry Schmidt 09-06-2016 11:07 AM
I have two or three sets of all thread Dilavar stud that I would be happy to sell to all you thrill seekers out there.......Let's say $ 300/set.
911pcars 09-06-2016 11:45 AM
Reusing all-thread Dilavar.
http://forums.pelicanparts.com/uploa...1473187459.jpg
We'll see.... when it runs.
S
chris_seven 09-07-2016 12:08 AM
Make sure the coatings aren't damaged or avoid salty roads :)
Tippy 09-07-2016 10:26 AM
Man, I was hoping you were giving away :)
