Squish height definition question
Hi,
For JE pistons, they specify 0.040" clearance to the head. Note that these are high dome. In measuring with solid solder, the thickness is only squished on the very steep sides, as in the pic. I'm seeing 0.035" thickness minimum where the arrows are. So, the question is, do we really care specifically about the clearance perpendicular (my 0.035), or do you consider it vertically, i.e. in the direction of the rod. Because the angle there is about 60 degrees, the head is at least 0.050 away from the piston vertically. http://forums.pelicanparts.com/uploa...1457404840.jpg Thanks |
Good question and interesting thought considering the direction not just magnitude. Looking forward to the experts answer.
I'm sure they'll all agree;) |
In real life, flat pistons are not usually the fair.
So to contribute here, I have always shot for .030 at the sides to help with all the benefits associated with this menu. That seems to be the standard number in the race industry today .( .030) Power is lost the further from the spark area as the gap between piston and head starts to enlarge. The piston starts for BDC and the squish keeps the pressure area tighter and more usable. To to make up for the loss, the piston and head should be tighter at the sides to take advantage of the explosion if you will. |
Thanks for the input. I did eventually find Bruce Anderson's line in his book stating 0.035".
To increase my clearance I would need another 0.25mm shim height, at the expense of about 0.3 compression ratio reduction. Or, I could maybe cut 0.004" from the side of the dome without reducing compression ratio hardly at all. |
I am not quite understanding what all what was done or what you are doing to your engine.
Why would you need to increase your clarence? something must have been machined? Squish has little to do with your C/R ratio. What do you have for squish right now? |
Measurements I have been taking are with new heads I'm installing. With old (wrong) heads I had probably 0.040 clearance if I remember. New heads have definitely had at least 0.010 machined off.
OK, Now i get it.
There are lots of ways to fix stuff. Each has its own merits. Generically speaking some heads designs will tighten the squish with milling, others (flatter more shallow chambers) material has to come off the bottom to get the piston closer to the top. Personally, I like the .030 number. Anything more than that is left on the table . I have even gone .028 on big old Harleys . No problems . |
Bruce Anderson was talking these types of pistons
http://forums.pelicanparts.com/uploa...1457575639.jpg Where mine looks like this http://forums.pelicanparts.com/uploa...1457575667.jpg Also I have the short stroke. |
I am not the end all of knowledge here .
What I think I know (pretty sure) is that piston wants a close squish at the edges. ( .030 )thou How you want to attain that is still up to you. The most EZ way is deck the case both sides. However , spinning some off the bottom of all six cylinders will be better for the next owner... I am not strictly a Porsche person. I would ask a shop that specializes in Porsche for their advice . ( Not your local machine shop) You could PM john Walker, and a few other Masters on here and see what they offer you. ( I would) |
Maybe someone can verify what the minimum piston to head clearance should be?
I have read .035". J&E recommends .040". I am talking about the edge of the piston compared to the top of the cylinder. Any thoughts? I don't see a clear consensus in this thread. BTW it's an SC motor with 95mm cylinders and J&E 9.5 to 1 pistons running Webers with the cams TBD.http://forums.pelicanparts.com/uploa...1464566547.jpg |
Like I said .030 works for everything i have done
Thanks.
I used .035" on my last build but it was with Mahle pistons. J&Es have that lip at the edge of the piston, I wasn't sure if that would make a difference. |
| All times are GMT -8. The time now is 08:01 AM. |
