-   -   Is This Normal on the Case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/905527-normal-case.html)
arbita1 03-09-2016 06:01 PM
I noticed this today on the bottom of my case. Is this normal?
http://forums.pelicanparts.com/uploa...1457575228.jpg
And why is there this much oil on my engine. Where is it coming from.
http://forums.pelicanparts.com/uploa...1457575274.jpg
E Sully 03-09-2016 07:01 PM
Looks normal. Triangle of death, leaky rocker shafts, valve cover gaskets, oil return tubes seals, head studs, fan blowing air and oil all over the place.
Pick any or all of the above.
afterburn 549 03-12-2016 07:52 PM
Looks like a job for- RSRS "O" rings on the rocker shafts!
boosted79 03-13-2016 06:36 AM
Are you talking about the file/grinding marks at the seam? That's just where they cleaned up the casting flash at the factory.
afterburn 549 03-13-2016 07:24 AM
You should have a groove all around each end of the rocker shaft(s)
arbita1 03-13-2016 07:45 AM
Yes. Thanks.
mreid 03-13-2016 07:51 AM
Normal, now get to work!
