Machine shop in western NY state or Toronto area?
Anything special about rebuilding 930 rods that a machine shop that does other automotive/diesel work can't handle? Anyone know of a machine shop in the Buffalo/Rochester, even Toronto area that does a lot of Porsche work?
Old 03-09-2016, 08:32 AM
Air Medal or two
afterburn 549's Avatar
A plain Jane shop should have no problem getting them round again.
I would stop there with the plain jane .
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-10-2016, 03:39 AM
Puny Bird
Mark Henry's Avatar
Most regular machine shops can do rods, you'll need to get the small end bushings for them. You can get those from our host.
Make sure you take a good piston pin with you and tell them that on the small end you expect a good slip fit with a tight tolerance.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-10-2016, 05:21 AM
OK, thanks. I have a shop I've used for other engines, they do a lot of work on auto, diesels and bikes so I'll talk to them. The heads and rockers are going to cgarr.
Luke M's Avatar
I've taken a few things here : http://www.mcquilleneng.com/
I purchased the parts and they did my 2.7 rod bushings install.
Ask for Carl he's the owner. They mainly do American iron but they will do VW/Porsche stuff too.
I was at his shop 4 months ago and they where building a type 4 there.
Old 03-18-2016, 05:20 AM
Thanks, it looks like a first rate shop judging by the equipment they have and the work they do. I think I'll take my rods there. I've got a 1965 VW double cab pickup that needs an engine job (it's on the list) so I know where to take it when I get to it.
Old 03-18-2016, 06:02 AM
