-   -   Dual to single pulley (http://forums.pelicanparts.com/911-engine-rebuilding-forum/907043-dual-single-pulley.html)
911 Rod 03-21-2016 01:20 PM
Now that my air con has been gone for years and I'm staring right at my double pulley would there be any performance gains in going to a single pulley?
I have one from an earlier car and it is a bit taller so hopefully I can change the shims to make the belt longer?
Does this mod worth spending time on or should I do more important things like finishing my engine?
Alan L 03-21-2016 08:34 PM
Finish the engine, and you would need a new belt , I doubt the shims will help if the pulley dia is different.
Alan
chris_seven 03-22-2016 03:12 AM
If you fit the smaller 116mm pulley you will effectively slow down the fan and the alternator by around 12%.
This will reduce parasitic losses due to windage but may reduce cooling a little in hot weather.
If you use this crank pulley with a later fan you will need a belt with a length of about 695mm.
Flat6pac 03-22-2016 05:00 AM
The largest pulley was used on the 77 to 79 with the like fan of the Carrera.
Install that pulley with a belt 9.5x725 you'll be good to go.
Bruce
911 Rod 03-22-2016 06:09 AM
The Single pulley I have is slightly bigger so would it not increase my fan speed?
Are there any advantages to the lighter pulley?
chris_seven 03-22-2016 09:27 AM
I always associate 'early' pulleys with the 116mm diameter of the early engines and these have a smaller effective diameter.
If you have a larger pulley then it will be faster:)
