-   -   GT3 crank on 3.2/3.4 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/907542-gt3-crank-3-2-3-4-a.html)
kenikh 04-26-2017 09:45 PM
Originally Posted by sp_cs (Post 9565966)
Have asked the question of the engine builder, nothing forthcoming just yet. Would (Pauter) rod lengths in this case be considered intellectual property ?
Anyway, bottom end together back together (inc Gt3 pump, steel IS gears), will share more pics once received.
http://forums.pelicanparts.com/uploa...1493243006.JPG
No.
Sent from my Nexus 6P using Tapatalk
racing97 04-27-2017 08:17 AM
Typically Porsche rods are avialable in a center to center lenght of 5.00 or 127mm if you like.
To figure this out you will need to measure from the center line of the case and add 1/2 the stroke and the rod center to center that will give you the reciprocating component to the center of the piston pin write it down. Measure the length of the barrel add it to the equation and subtract or first measurement from it that the difference minus your ascribed deck height will give you the Compression Height of the piston, figure what compression ratio you want (this is different than compression height) and call a good Piston manufacturer he will go over your figures with you and Wa La.
Basically that is how it is done.
regards
sp_cs 05-16-2018 11:50 AM
Gents - i'll add more pics once the builder has sorted them onto a USB stick, however the work is largely done.
Some minor fettling required (proper oil catch tank) and a map tweak
Reminder of spec:
Gt3 crank
Gt3 pump
Pauter rods
AT Power ITBs
William Knight 5mm cams
993 plastic intake with resonance flap
All this on top of my current 98mm mahle/3.4 setup with motec/COP and SSIs
Performance is in a different ball park. Cams (circa GE100 spec) are not at all peaky and come in strong from 2750rpm. Pulls hard through 6k, and feels like it will still produce power 7k with ease (even with SSIs)
Still needs a power run, hopefully in a couple of weeks. No comparative before dyno plot, as costs escalated and i cannot afford to run it on the builders engine dyno.
http://forums.pelicanparts.com/uploa...1526500238.jpg
Peter M 05-17-2018 01:28 AM
Shirish,
Nice build!
What Motec ECU are you running?
Are you using Bosch 0986 221 024 CoP's?
Do you know what injectors you are running and at what pressure.
Love you neat manifold and ITB setup!
sp_cs 05-17-2018 02:34 AM
Hi Peter, thanks
Motec M84
COP - Audi 06A.905.115.D, unsure what Bosch equiv p/n is
Injectors - ASNU 300cc / 10deg spray pattern
I’m not entirely happy with the K&N filter/layout and may look to adopt a more traditional layout with a filter box in the future.
Peter M 05-19-2018 02:55 AM
Thanks Shirish,
Yes they're the same coils.
Regards
sp_cs 03-01-2019 12:35 PM
So, i’ve recently collected the car after some rework.
The valve stem seals were found to be problematic; it stunk of oil at idle and it was puffing smoke - all of this after a significantly expensive rebuild. Lots of oil consumption too. Sub-optimal, you’d agree.
A decision was also made to go twin plug with some additional Bosch CoPs, to accommodate some 11.5:1 JE pistons, cc’d at 11.65:1, to replace the 10.2 Mahle.
The final piece was to fit some ‘F Modell’ 42mm OD Eisnemann h/ex
Old (Mahle) v new (JE)
http://forums.pelicanparts.com/uploa...1551474682.png
GT3 crank and Pauter 127.8mm rods:
http://forums.pelicanparts.com/uploa...1551474827.jpg
New JEs fitted:
http://forums.pelicanparts.com/uploa...1551475222.jpg
port matching on intake side:
http://forums.pelicanparts.com/uploa...1551475520.jpg
All important Heet Sheets!:
http://forums.pelicanparts.com/uploa...1551475996.jpg
Outgoing 993 intake setup:
http://forums.pelicanparts.com/uploa...1551475733.jpg
Incoming Velocity stack setup:
http://forums.pelicanparts.com/uploa...1551475860.jpg
sp_cs 03-01-2019 12:39 PM
Guess which curves are for which setup (thin or thick lines?
Both 993 and velocity stacks were dyno’d with the 11.65:1 pistons, twin plug and 42mm Eisenmanns.
http://forums.pelicanparts.com/uploa...1551476307.jpg
sp_cs 03-01-2019 02:47 PM
http://forums.pelicanparts.com/uploa...1551484042.jpg
Arlo911 03-01-2019 10:08 PM
Hi Shirish, is that a TT muffler?
sp_cs 03-01-2019 10:41 PM
Hello Arlo, nope, it’s a DW Technik muffler.
On a previous back to back test dyno test, it delivered 6bhp more than a Dansk 2in1out.
Arlo911 03-02-2019 06:29 AM
Ah yes, Dieter does amazing work! I had one of his mufflers on my 3.2. Awesome sounding too.
Mixed76 03-05-2019 10:03 AM
So, which intake made big lumpy power?
Sent from my Nokia 7.1 using Tapatalk
sp_cs 03-05-2019 11:18 AM
Stacks are the “lumpy” curves.
Surprised me though. I was expecting a stronger torque curve with the plenum; it’s flatter but not much stronger.
Mixed76 03-05-2019 12:32 PM
Surprises me too. I expected the stacks to be lumpier, but the plenum to give more ultimate power.
Dan
stownsen914 03-05-2019 06:42 PM
Looks like a nice build with some nice dyno numbers to show for it!
I'm curious to know the cam grind if you are able to share. A few posts back you mention a grind 5mm grind similar to GE100, but I'd think a GE100 wouldn't be very friendly for anything other than all out racing. Maybe yours is something a little milder?
sp_cs 03-06-2019 12:19 AM
Probably best you contact William and mention my name.
I believe this spec is his default now for all 3.2 and above with ITBs
Jonny042 03-06-2019 05:31 PM
Nice build! SO neat that you can piece these things together from the parts bin and come up with such a fantastic powerplant! I have a GT3 crank in the basement....
Any comments/feedback/opinions on the Eisenmann HE's? They look good, the little we can see from the pics - the secondary pipes look like they might be a bigger diameter than the the SSIs?
sp_cs 03-06-2019 10:38 PM
Yes agreed, I had one of Dieter’s on my 88 911 CS back in 2004, I loved the sound it made but this is significantly quieter. Must be Swiss spec :)
sp_cs 03-06-2019 10:42 PM
The GT3 crank is a thing of beauty to behold, and to think it is (was?) less than half the price of a new 3:2 crank.
I can check the OD of the Eisenmanns this weekend. Overall quality was excellent, although there as an alignment issue with one of the outlets - an hours labour to slice and re-weld.
Jonny042 03-07-2019 07:13 AM
If you have a chance to measure it would be great. By one of the outlets, you mean the secondary connection from the header to the muffler?
Certainly seems like the 42mm HE's support a good HP number!
sp_cs 03-07-2019 09:26 AM
Re outlets, yes correct, one flange wasn’t flush with the muffler inlet.
tabasco 03-09-2019 06:54 AM
Can you share some info on the velocity stacks air filter setup? Is that available off the shelf or custom made?
And when you used the 964 plenum, where did you source the air filter setup? Gamroth?
sp_cs 03-09-2019 12:14 PM
54.5-55mm OD - slight variation along the length, but similar side to side
sp_cs 03-09-2019 12:27 PM
Stacks come as part of the kit with the ATPower setup.
Rothsport wouldn’t sell me the filter setup on its own, so we had one made. The filter is available off the shelf.
Mine is available for sale - plenum, resonance tube, vacuum activator, filter and the legs that join the plenum to the flange with the heads. You’d need to sort the 2 bolt adaptors for the legs to mate with - I think Jenvey may do them, or turbokraft.
Jonny042 03-12-2019 04:54 AM
Interesting - the older US-made SSI's I have hanging on the wall have secondaries that measure a few mm smaller than that, maybe 52-53mm OD.
The Dansk stainless muffler bolted to them has inlet tubes that are exactly 50mm OD.
Would be interesting if the eisenmann muffler has matching inlet diameters.
lvporschepilot 03-12-2019 06:38 AM
Great set up! Do you recall how much ignition timing in total is being used at WOT?
Jonny042 03-13-2019 07:11 AM
Part number P91130.WT42 is correct for the Eisenmann HE's? Waiting on a shipping quote for them.
Thanks and all the best!
sp_cs 03-13-2019 07:30 AM
Yup
http://forums.pelicanparts.com/uploa...1552491003.jpg
sp_cs 03-13-2019 07:31 AM
Will check
sp_cs 03-13-2019 09:52 AM
Qualification - this is the right part for SSI muffler compatible Eisenmann. The alternative is the 3.2 setup, which mandates the Eisenmann muffler
Jonny042 03-13-2019 06:47 PM
Nope that's perfect, thanks!!! I understand the difference with the G series model. Pics on their website aren't 100% representative. The pics of yours and the pic of the part number are especially helpful, thanks again.
sp_cs 03-15-2019 04:24 PM
Couple of v quick acceleration vids, I love the way it sounds:
https://youtu.be/EKQ0eRZnCAM
https://youtu.be/50EtM1ElpQg
QueWhy 03-18-2019 05:10 PM
Sounds fantastic in the videos.
Mixed76 03-21-2019 06:34 PM
I see that ATpower makes 911 itb's in 42 or 45mm. Which did you use? Did it match up well to the plastic plenum?
Dan
sp_cs 03-21-2019 11:28 PM
Dan
45mm as they taper to 42mm at the heads, optimal for 3.2 heads; some mild port matching was also undertaken.
The 42mm taper to 40mm - I think better sized for a 3.0
We chopped the plenum legs and added silicone joiners
http://forums.pelicanparts.com/uploa...1553239590.jpg
Litle brother 05-24-2019 12:28 PM
Great [emoji106]
