Certainly seems like the 42mm HE's support a good HP number! |
Re outlets, yes correct, one flange wasn’t flush with the muffler inlet.
Can you share some info on the velocity stacks air filter setup? Is that available off the shelf or custom made?
And when you used the 964 plenum, where did you source the air filter setup? Gamroth? |
Rothsport wouldn’t sell me the filter setup on its own, so we had one made. The filter is available off the shelf. Mine is available for sale - plenum, resonance tube, vacuum activator, filter and the legs that join the plenum to the flange with the heads. You’d need to sort the 2 bolt adaptors for the legs to mate with - I think Jenvey may do them, or turbokraft. |
The Dansk stainless muffler bolted to them has inlet tubes that are exactly 50mm OD. Would be interesting if the eisenmann muffler has matching inlet diameters. |
Great set up! Do you recall how much ignition timing in total is being used at WOT?
Thanks and all the best! |
http://forums.pelicanparts.com/uploa...1552491003.jpg |
Couple of v quick acceleration vids, I love the way it sounds:
https://youtu.be/EKQ0eRZnCAM https://youtu.be/50EtM1ElpQg |
I see that ATpower makes 911 itb's in 42 or 45mm. Which did you use? Did it match up well to the plastic plenum?
Dan Sent from my Nokia 7.1 using Tapatalk |
The 42mm taper to 40mm - I think better sized for a 3.0 We chopped the plenum legs and added silicone joiners http://forums.pelicanparts.com/uploa...1553239590.jpg |
Great [emoji106]
Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 03:09 AM. |
