-   -   Pelican who does head work? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/908017-pelican-who-does-head-work.html)
Slanski62 03-28-2016 02:26 PM
Hi. I'm trying to contact the Pelican who's been recommended to rebuild heads. His user name is something like Gcarr but I can't find him through search. Would someone please pass my info along to him? Thanks folks.
Flat6pac 03-28-2016 02:43 PM
Try cgarr
Bruce
Wheelsonly 03-28-2016 03:21 PM
I dabble have seat and guide machine
boyt911sc 03-28-2016 03:33 PM
Machine shop.....
Craig Garrett aka cgarr.
Tony
boosted79 03-28-2016 04:30 PM
Craig Garrett, will be getting my heads and rockers back from him this week.
Slanski62 03-28-2016 04:35 PM
Thanks guys. Craig contacted me already.
wprater 03-28-2016 10:38 PM
I had work done by Craig as well. great work! would recommend his work for sure.
Ken911 04-18-2016 08:15 AM
xtreme in florida also does CnC head work. they also manufacture the heads for the singer engines. He did the heads for my turbo. cnc machined them twin plugged them, replaced the guides and valves, cut them for flame rings. Inconel exhaust large diameter valves with small diameter stems. stainless large diameter intakes with small diameter stems.
Tippy 04-18-2016 08:35 AM
+911 for cgarr!
Ken911 04-18-2016 08:56 AM
Cgar will be getting all my rocker arms. when I get around to working on the car again and not the house.
IXjamesXI 04-19-2016 06:00 AM
Anyone got current contact info for him? I tried an old email address which I think is now defunct. Also tried phone (could be old?) and PM to no avail. PM me if you've got his current number.. Got some bushings questions for him. Thank you!
awjens 04-19-2016 06:50 AM
Exoctec
Exotech in NH also does 911 heads
Wheelsonly 04-19-2016 10:04 AM
I do cylinder heads also out here I California http://img.photobucket.com/albums/v2...psknn93pci.jpg
Tippy 04-19-2016 10:41 AM
There's tons of places who do cylinder heads, but they cannot touch Craig's pricing, turn-around, nor customer service.
SexOnTheBeach 04-20-2016 05:26 PM
Did not know they do the Singer heads, out of a bare cast??, can you confirm?, to manufacture them is one thing, then to modify the oem ones is another.
0396 04-20-2016 06:02 PM
Care to share your location in California? Thanks
Wheelsonly 04-21-2016 05:53 AM
San Jose.
Ken911 04-21-2016 07:38 AM
Yes he machines them from bare castings. The alloy he uses is the same alloy as the 993 turbo head, which is a little different than the rr350 alloy used on my 930 heads. He had a big stack of them in his shop when I was there that were for singer.
Ken911 04-21-2016 07:51 AM
here are my heads the injector notch was welded up. Larger valves with 8 mm stems, cnc machined porting, twin plugged, flame ringed, Inconel exhaust valves, and if you notice the valves are very thin at the base which allows more flow.
http://forums.pelicanparts.com/uploa...1461253792.jpg
http://forums.pelicanparts.com/uploa...1461253821.jpg
http://forums.pelicanparts.com/uploa...1461253835.jpg
http://forums.pelicanparts.com/uploa...1461253849.jpg
http://forums.pelicanparts.com/uploa...1461253858.jpg
http://forums.pelicanparts.com/uploa...1461253867.jpg
mb911 04-22-2016 10:25 AM
Subscribed as I was looking for Craigs number as well for my heads.. He did my last set and a great job as well..
SexOnTheBeach 04-22-2016 04:51 PM
Great, I'll be calling Bill, see if can do me some 993tt heads, cheers.
