Suggestions for a warmed over SWB
Hello guys
I recently acquired a '68 mag crankcase in excellent condition and I'd like to build an engine using this case. I know that many SWB guys prefer aluminum sand cast cases but I'm not a fan of carbs.
Since I already have an 005 MFI pump that I've saved for a long time, I'd like to use a specification that will work with this type of pump
Do you know if 005 MFI is compatible with 901/02 (67S/68S)?
Can '68S heads be drilled for MFI ports or would it better to look for later MFI 2 liter heads?
Which velocity stacks are best for 901/02? 2.0E or 2.0S?
Old 04-05-2016, 08:11 AM
3 restos WIP = psycho
kenikh's Avatar
I'd do what I did again: DC30 cams. They wil work well with that E pump, as well. '68 heads are easy to drill for MFI injectors and would choose E stacks and TBs over S. The smaller bore will be a better match for the cam/pump combo. That combo in a light SWB hauls ass - I can run down much faster cars on twisty roads with this combo. And it is a blast to drive and makes all the right noises.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-14-2016, 04:15 PM
005 is actually an S pump, which is what i've got and I'd rather keep it than change it for an 006. Will DC30 cams, E stacks & TB's still work with S pump?
Good to hear that 68 heads are easy to drill for MFI injectors.
Old 04-15-2016, 06:43 AM
kenikh's Avatar
You're right. My brain was switched off yesterday. 001 is early 69S, 005 is late. DC30s will still be fine, as they are closer to S than E. I'd still use E stacks.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-15-2016, 06:58 AM
