-   -   79 SC - removing heat exchangers - stud came out (http://forums.pelicanparts.com/911-engine-rebuilding-forum/908244-79-sc-removing-heat-exchangers-stud-came-out.html)
pbeezy 03-30-2016 05:10 PM
Hi. I recently bought a 911SC and am removing the stock heat exchangers and muffler to go with SSIs and a sport muffler (I'm following Wayne's book - Chapter 44).
As I was removing the nuts, with a little WD40 and heat, 5 came off without any consequences/surprises. One, however, brought the stud out with it. I don't think the stud broke (actually, I should confess I don't know how long the stud should be) but there appears to be no fracture or break. There is also plenty of thread to use the rusted/melded stud/nut combo on the installation of the new SSI heat exchanger.
Am I missing anything here? Did I do harm that I don't appreciate. Is it OK to use the stud/nut (I'll use new nuts for the others). Pics are below.
Best,
PB
http://forums.pelicanparts.com/uploa...1459382951.jpg
http://forums.pelicanparts.com/uploa...1459382967.jpg
jason2guy 03-30-2016 06:10 PM
get a new stud and new bolts for all the studs
pbeezy 03-30-2016 06:28 PM
got it. im such a noob. just figured out that ideally all of the studs come out. i'll leave the 5 in that didn't want to come out and replace that 1. thanks
theiceman 03-30-2016 07:00 PM
You were lucky none of them snapped
Good work.
