1979 930 @outlaw3.4
MZ3 SBC's Avatar
Bosch Twin Plug wiring Schematic- HELP please
I believe that I have an RSR type BOSCH twin plug. I removed it during a motor out service. The project took all winter and the index markets got smudged off...so I am pretty sure I don't have the timing right. I need to make sure the wiring is correct to the proper pistons / top and bottom. Then set the timing.
I have searched all the threads, been to JB rcing and Raceservice4u etc.
any help would be appreciated.
Old 04-19-2016, 07:05 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Some pics of the distributor
Old 04-19-2016, 07:16 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
would it be same as one of these?-
Old 04-19-2016, 07:28 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
So if I know the 930 dist counter rotates, and I know the firing order is 1-6-2-4-3-5, and timing is 10degrees advanced TDC....then I have to set the CYLINDER #1 to TDC - the question is how to address the second set of plugs......
Old 04-19-2016, 09:02 AM
356RS's Avatar
I just posted to your question on the Technical Forum side.
Mark Jung
Bend, OR
MFI Werks.com
Old 04-19-2016, 09:45 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Thanks Mark- I read it...
much appreciated,
"It looks like the red and black dots are on a #1 & #4 marking. Looking at your photo of the top of the cap, the red marking @ 12 o'clock could be where the #1 B is and then CCW to the #6 B is a black marking. Same for the #1 A black marking @ the 1 o'clock position, CCW to the #4 A red marking @ the 7 o'clock position. The A connectors are on the outer plug connectors and the B's are the inner connectors. "
Old 04-19-2016, 11:54 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
moved over to ...Bosch Twin Plug Cap
Old 04-20-2016, 06:40 AM
