-   -   cam tight on reassembly. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/909324-cam-tight-reassembly.html)
theiceman 04-07-2016 11:37 AM
during my top end rebuild I sent my cams off for a 964 grind . They came back all black and new looking and sit in there rolled up paper reasy for reassembly.
Now I have found although one of the cams fits in the housing it is fairly tight . I can turn it by hand but with a struggle ( dry without assembly lube. )
the other cam will turn in either housing without any issue at all.
I have reached out to the guy who did the cam grind but thought would seek an opinion here while I am waiting . it seems to bind up on the second journal in ( not that it matters ) as once you pass that with the cam it struggles. again happens on both housings.
Think I need to get the cam relooked at ( I had to have it sent away )or should I slap it in with some assembly lube and move on ?
IXjamesXI 04-07-2016 01:21 PM
More likely that the housing is slightly warped. Try re installing it
cgarr 04-07-2016 01:34 PM
Measure both cams, A polish might take care of it: I assume this is checked not assembled on the motor?
theiceman 04-07-2016 01:48 PM
not the housing .. the housing is fine with the other cam. I have the other housing assembled on the heads and wrapped up in plastic I will check it with this cam later ..
yes you are correct cgarr it is not on the motor . I did assemble the heads on to the cam housing so thinking thiis may have been an issue ( even though I used the correct torque sequence. ) I backed off the torque on the head - housing and checked again , exactly the same problem.
The cams did come back completely black and I was told it was some type of hardening they do. The cam guy is going to get back to me so we will see what he says.
good point on measuring the cam , I never thought of that. I might build some device so I can see if I have runout.
I have not put any lube or anything on it either to be fair as I was not sure what to expect as "normal"
Flat6pac 04-07-2016 02:08 PM
You probably can't fit the back chain gear on either.
Bruce
boyt911sc 04-07-2016 02:49 PM
Cam test fit........
Install and try to test fit the good cam in both cam towers. Repeat the process using the problematic cam. Apply some assembly lube on both cams. Keep us posted. Thanks.
Tony
theiceman 04-07-2016 07:35 PM
Hi tony
Good cam fit smoothly.into both housings
Bad cam fit in both with some help and can be turned but with some effort and squeels like a pig
Lube is next.
Steve@Rennsport 04-07-2016 07:45 PM
Assembly lube is not going to fix it. :)
I'd recommend installing into some live centers (lathe) and check to see if its bent.
Alan L 04-07-2016 08:58 PM
The hardening can add a smidgen to the diameter. As posted earlier I suspect you might need to polish it down a fraction (we are talking less than a thou basically). Easiest done in a lathe, but hopefully your cam guy may offer if handy close. if you had a micrometer, you may be able to measure a small difference between the two.
Alan
afterburn 549 04-07-2016 09:13 PM
I have seen this B4 When back from a regrind.
From what you describe I have seen a lot worse.
Its not an emergency.
Try to determine the tight spot and polish it like said .
If not too tight no one will ever notice anyway.
BUT-
The reasons can be wrong torq sequence .
Incorrect cyl HT(s)
and
Remember they welded on the cam...It may forever have a wiggle in it.
theiceman 04-08-2016 06:52 AM
all good advice guys .
i will start off with a polish . I actually have a buffing wheel for my tabletop grinder , would this be acceptable ? i think less than a though would be accurate as it squeeks but is turnable with a fist as oppose to fingers on the other side. ( there is a spot it is loose but tightens up when turning. )
I am glad to hear it doesnt sound too serious. its not like its jammed or wedged in there.
I will polish and update you all
Thanks again
john walker's workshop 04-09-2016 08:22 AM
If the journals are parkerized, remove it. Same for the nose where the back gear goes on.
prschmn 04-09-2016 12:38 PM
+1 for John Ws thought
Steve@Rennsport 04-09-2016 03:07 PM
This is precisely why I suggested making sure it was straight.
Gordo2 04-09-2016 04:43 PM
3.0 Cams to 964 Profile?
I thought the stock 3.0L cams could be ground to the 964 profile - no welding required???
I'm with John W BTW - the parkerizing adds enough material to make stuff not fit right (technical terms...).
I needed to polish the ends of my cams down (removing the black parkerized surface) to get the cam gears on mine.
Good luck, Gordo
afterburn 549 04-09-2016 06:03 PM
Sorry.......speed reading here.......
theiceman 04-10-2016 06:07 PM
ok guys I have an update
so now I know "parkerize" is the black stuff on it.
I polished it for hours with a piece of jean material on all 4 bearing surafces. I thought my arms were gonna fall off by the end. the black started to lighten up to a bronze colour. I was eventually able to put it in the housing and get it to turn without squeeking and with less resistance. it had a "tighter" spot for about 45 degrees of rotation so I decided to try it with assembly lube .. success, the lube actually makes it overall a little tougher to turn as its quite thick but overall its the same as the other side .. so great success so thanks to everyone.
a related question. I have been reading how many of the experienced engine builders now put everthing together on the bench. heads housing cams and rockers , then pop it on the studs.
is there any issues with getting the chain over the cams or getting the chain boxes in place when doing it this way ?
thanks
john walker's workshop 04-10-2016 07:39 PM
No issue. Just need to set the engine on TDC and have the cam keyways facing up when you install the assemblies. Way faster and easier.
Alan L 04-10-2016 08:10 PM
thanks
I am not sure what the shop guys do, but I have used 1200 wet/dry before for that. Might be a bit easier than jeans. But job done, and the finer the better if you can stand the pain.
Alan
boyt911sc 04-10-2016 09:13 PM
Adverse effects........
John,
Any adverse effect if you do not remove the parkerized coating on the bearings of the camshaft? The cam grinders send back the newly refurbished or rebuilt cams without any specific instruction about removing or polishing 'Parkerize coatings'. Thanks.
Tony
