-   -   Zenith vs Webers on 2.7 carb conversion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/910223-zenith-vs-webers-2-7-carb-conversion.html)
RSSweden 04-14-2016 08:47 AM
Hi
I am doing a full rebuild of my 2.7 CIS including a carb conversion. The choice stands between Zenith and Weber 40 mm carbs. The engine spec is relatively aggressive with high compression pistons and RSR-ish cams. Views on preference or will they both do the job?
Thanks!
Trackrash 04-14-2016 09:21 AM
I could not get Zeniths to perform adequately on my 2,5 motor. I gave up and changed to Webers.
Webers have parts, jets and venturis etc readily available. Zeniths do not.
There are some on this board who claim to have had success with Zeniths, maybe they will chime in.
chris_seven 04-14-2016 09:31 AM
There are now plenty of jets, and chokes available for Zenithsand they can perform well with a bit of patience.
RSSweden 04-14-2016 11:22 AM
Thanks! Any difference in power between the two?
VFR750 04-14-2016 12:25 PM
I doubt there is any difference because you'll end up with the same size venturis and jets for the same AFR. 40mm zenith vs 40mm weber.
The parts are available on eBay via alfa1750.
