930 lrockee or rod noise and smoke at startup?
Hi guys whats your take on this noise on my 89 turbo 911
1000 mi on rebuilt engine https://youtu.be/gqLtsDCmL4k I adjusted the valves at 500 mi can it still need adjustment? I also get a puff of white smoke at startup . Is this normal I have been using kirts valve tool , I might not know how to use it well Is it possdible to open the valve just by turning the screw? When I turn in the screw is goes down easy then stops , i can continue turning but with some force , am I opening the vslve at thst point?Thanks Erick Last edited by ertech; 04-16-2016 at 08:54 AM.. |
Air Medal or two
Pull the valve covers and inspect.Thats the most EZ.
Look for loose valves and or a rocker shaft that slid out.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
